Stu2010
Hi there
I'd really appreciate some estimates on how long a tiling job might take. The tiles are 25cm X 33cm ceramics and they are to be put on the wall horizontally, but in an overlapping brick effect style - Toll area is 22 square meters. There 3 will also be tile wide strip of mosaic running around the whole room about half way up the wall.
There is also a recessed window with a 20cm wide ledge all the way around.. The window is 80cm X 50cm and I have to tile the top, sides and bottom of this window area and add tile trim
The wall is not perfectly straight.. I’ve noticed it bows in about 0.7cm to the centre of each wall.
So... can anyone give me a rough estimate as to how long this would take a decent pro to do.. I don't want a lightning speed quote.... just a rough, reasonable idea of timeframes for how long the job should take a reasonable pro tiller
thanks a lot
Cheers
Stu
thanks a lot
Cheers
Stu
