Discuss How many Sq Metres a day can you lay natural stone? in the British & UK Tiling Forum area at TilersForums.com.
mikey3000
Hi there, new to the forum, and the trade. I'm currently working on a development of five new houses in Essex (bathrooms, kitchens, floors/hallways) in limestone (600 x 400 floors, 400 x 400 wall) before doing an ICA course starting mid-April and I'm getting excellent quality results, but I am SLOW!
So I was wondering, what meterage would a pro tiler with years of experience (like all of you on this forum) expect to be able to lay per day? (I've got all the gear, Rubi wet-cutter etc, no excuses, but I'm doing only about 3 - 4 sq metres a day - taking AGES to get the tiles level on the floor. Client wants brick-work pattern, so nowhere to hide if there are lips).
In case you're wondering how I got the job (given my inexperience), the developers (small time, tight) decided to stop paying for contractors and so told their two full time employees (one of which is my next door neighbour) that they had to do all the tiling themselves. But because there is so much of it (esp the hallways/dining room and kitchen floors) he didn't want to do it, so recommended me to them on the cheap (£20 a sq metre, laid, grouted and sealed. Hey, I'm soon to be paying Able Skills for the privilege of tiling a mock-up bay, so I figured this is real work, for real clients, so it's a great practice and experience). Having worked a full week I'm probably £180 up (after all the preparation that was necessary to the floors - out of 5 days I got 2 1/2 days of laying plus a few hours grouting).
If there is a magic secret of how a pro would do a much higher meterage PLEASE let me in on it (I suspect it may be because my beds are too thick - I'm putting on the floor and buttering the back of the floor tiles, but there's a 3mm high point in most of the floors, and the rooms/halls all interlink so I couldn't think of any other way, apart from chiselling off loads of screed all over the place)???
Thanks in advance (and if anyone wants to laugh at my predicament, that's cool too - it's all a learning curve. Anyway, it's Friday so I'm off down the pub in a minute to squander my hard-earned :8:
Mikey
H
hillhead
hello there mikey,
seems like your havin fun? lol.
them floors may need some levelling compound,at the rate you tiling you'll be on them houses to next year,lol,joking.
In dublin last year i was getting 60 euro a metre,40 quid and was laying 15 -20 mt a day,but 20 sterling is about right up north here.
good luck kid,your speed should come eventually.
JOHNNYCLARKE
mikey
Sounds like youve landed that great opportunity you needed before youve even officially started.
Youre doing the right thing to get it right first.
Speed comes with time and alot of time.
Havent got time this evening but will gladly give you some pointers.
Just remember , anyone can put a tile on the floor on top of some adhesive but there is a big diffrence between laying ceramics with a notched trowel and laying a stone floor like a billiard table with no lips.
Quality is the key to sucess.
Johnny
mikey3000
Hi MZ I am using a 10mm trowel. Maybe a larger one would be better, or a solid bed (U shaped one)???
Overall the floor is pretty good, just high at the doorways, and going slightly uphill in the kitchen.
Thanks very much for the words of encouragement Johnny, that's what I figured - quality first.
It's also frustrating that we can only get into the site at 8 a.m., nothing gets started til 8:30 (they all want tea and to sledge each other), there are two forced breaks (10 and 1) and then we get kicked off-site at 4:30. If you get 7 hours a day of work in it's a miracle. Personally I'd want to be working at least 4 - 5 hours longer per day than that. Maybe I'd get 5 sq m's done then ;-)
All the best, Mikey
Hi Hillhead, yep, lot's of fun!
15 - 20 sq m a day, WOW! :whatchutalkingabout
I can see that I have a LOT to learn :mad2:
sWe
Mikey3000, if the layer of adhesive is thick enough to balance out any diffs in the thickness of the individual pieces, and the floors are fairly level, a tip would be to use a plank or a board as a level guide.
You lay it on the freshly laid pieces, and when there are lips, you'll see exactly where and if you need to tap the pieces down a bit, or if you need to put down more addy. You can either tap the plank with a mallet , or tap the individual pieces. Double check the levels with a spirit level afterwards, so you didn't go to far. Make sure to clean away excess addy in the spacing.
Using this method, you can smack down a row, go over it with the plank and match it to the rest of the floor faster than if you gauge with eyes only.
sWe
Thanks very much indeed sWe, that's excellent, I'll try that on Monday.
I guess the trick is to put on more adhesive rather than less, as it's easier to push the tiles down a bit and remove excess from the spacing than it is to lift tiles to put more down if they are too low, is that right??
All the best,
Pretty much, yeah. Do remember though, that different adhesives are made for different applications and thicknesses. If you have to go thicker than what the manufacturer recommends for the particular adhesive you're using, it might not cure properly, and crack, or something else undesireable.
Daz
Hi Mikey and welcome,
Hang in there, I have only been going full time since the start of this year and can already see a marked improvement in my speed.
I recently had to lay 150m of porcelain (400 x 400) in a barn conversion and I think the bloke that laid the screed must have been bladdered 'cos it was 35mm higher at the main entrance than in the kitchen. I just took my time and "packed" tiles, where neeed, and the floor ran smooth (albeit uphill - lol!).
I can't offer any tips to improve your speed but concur with previous comments that quality should always come first.
Good luck.
Reply to How many Sq Metres a day can you lay natural stone? in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
