DHTiling
I normally use lithofin products but found this useful topps fila products care guide..great stuff........dave..
How to Care For & Maintain Natural Products
Initial Cleaning
GROUT FILM REMOVER
FOR LIMESTONE,
TRAVERTINE, POLISHED
MARBLE, SLATE,
SANDSTONE AND
POLISHED GRANITE
1:30
50m2
WHAT IT’S FOR
• A cleaner for removing building site dirt, installation residues and
any type of limescale
ADVANTAGES
• High performance on a wide range of floor surfaces
• Cleans without damaging the floor surface
• Highly biodegradable
HOW IT’S USED
1. Dilute Residue Remover (Neutral) 1:5-1:30 depending on the level of
deposits to be removed
2. Spread the solution over the floor with a rag and leave to act for a few minutes
3. Use a floor scrubbing brush or a single-disc professional polisher.
Vacuum or wipe up residue
4. Rinse with water
ACID GROUT FILM
REMOVER FOR
PORCELAIN STONEWARE,
UNPOLISHED MARBLE,
UNPOLISHED GRANITE,
GLAZED CERAMIC AND
TERRACOTTA
1:5/1:10
20/40m2
WHAT IT’S FOR
• It removes building-site dirt, installation residues, any saline efflorescence and
any type of lime scale
ADVANTAGES
• Does not develop harmful fumes
• Does not alter the surface appearance or colour
• Does not damage grouts
• Does not harm aluminium or steel trims
HOW IT’S USED
1. Dilute Residue Remover (Extra Strong) 1:5-1:10 depending on the level of
4. Rinse with plenty of water
Protection
STAIN PROTECTION FOR
POLISHED PORCELAIN
25m2
WHAT IT’S FOR
• Protects porcelain floors from stains and dirt
ADVANTAGES
• Does not yellow with age
• Provides long lasting, renewable protection
• Does not leave any filmy residue
• Penetrates deeply, protects and makes cleaning easy
HOW IT’S USED
1. Clean with Residue Remover (Extra Strong)
2. When dry, apply a continuous coat of the product with a brush or roller
3. Leave for 12 hours (at least)
4. Wipe off any residue with a dry cloth or floor polisher
5. Any stubborn residues due to over-application can be removed with
a cloth dipped in Fila Stone Stripper
Polished Porcelain Impregnator Sealer
www.toppstiles.co.uk
POLISHED TRAVERTINE
& MARBLE
20m2
WHAT IT’S FOR
• Protects Marble/Travertine floors from stains and dirt
ADVANTAGES
• Certified as suitable for use on food contact surfaces
HOW IT’S USED
1. Clean with Residue Remover (neutral)
2. When dry, apply a continuous coat of the product with a brush or a roller
5. Any stubborn residues due to over-application can be removed with a cloth dipped
in Stone Stripper
Polished Travertine & Marble Impregnator Sealer
GRANITE
10/20m2
WHAT IT’S FOR
• Creates an effective barrier against stains
ADVANTAGES
HOW IT’S USED
1. Clean with Residue Remover (neutral) for polished granite, or Residue
Remover (Extra Strong) for unpolished granite
2. When dry, apply with a brush or a roller a continuous coat of the product
Granite Impregnator Sealer
UNPOLISHED TRAVERTINE
& TUMBLED MARBLE
1 litre
20m2 per coat
WHAT IT’S FOR
• Protects unpolished travertine and tumbled marble against stains and water absorption
ADVANTAGES
• Water based
HOW IT’S USED
1. Clean with Residue Remover (Extra Strong) diluted 1:10 in water
3. Apply a second coat within 4 hours
4. Wait at least 4 hours before walking over the floor
Unpolished Travertine & Tumbled Marble Impregnator Sealer
IMPREGNATOR SEALER
LIMESTONE
10m2 per coat
WHAT IT’S FOR
• Provides protection for limestone
ADVANTAGES
• Water based
HOW IT’S USED
1. Install floor / fix walls as per requirements
2. Wipe off any excess dirt and adhesive etc
3. Prior to grouting (Pre-sealing necessary) apply a continuous coat of
the product with a brush/roller
4. Leave for 2 hours or until dry
5. Grout as per required effect
6. Clean with Residue Remover (Neutral)
7. When dry apply a second coat of the product
8. Wait at least 4 hours before walking over the floor
Limestone Impregnator Sealer
ENHANCER FOR
UNPOLISHED STONE
10m2 per coat
WHAT IT’S FOR
• It’s a colour enhancer for most types of unpolished natural stone including
Travertine, Tumbled Marble, Slate and Sandstone, etc
ADVANTAGES
• Does not yellow
• Resistant to peeling
• Easy to apply
• 2 in 1: protection and enhancer
• Wet look
HOW IT’S USED
1. After checking the wall/floor is clean, brush/roller/sponge on a continuous
coat of Colour Intensifier
2. Wait 12 hours then apply a second coat if required
3. On particularly absorbent stone, a third coat may be required to give a better effect
Colour Intensifier
SLATE
1 litre
20m2 per coat
WHAT IT’S FOR
• Protects slate against stains and water absorption
ADVANTAGES
• Water based
HOW IT’S USED
1. Clean with Residue Remover (Neutral)
3. Within 4 hours, apply a second coat
Slate Impregnator Sealer
Routine Maintenance
FOR ALL GROUTING WHAT IT’S FOR
• For cleaning grout joints in tiled walls and floors
ADVANTAGES
• Specific detergent for cleaning the grouts in ceramic tile walls and floors
• May be used on grouting for surfaces made from marble, tumbled marble
or agglomerates, provided they are not protected or treated with wax
• Does not damage the tile surface
• For all types of grout joints (cement and epoxy)
HOW IT’S USED
1. Apply the product directly onto the grout
2. Leave for a few seconds
3. Scrub with an abrasive sponge or floor scrubbing brush
4. Rinse with water
Grout Cleaner
ROUTINE CLEANER FOR
CERAMIC AND
NATURAL STONE
1:200
1,500m2
WHAT IT’S FOR
• A routine cleaner for all types of tiles, as well as marble and granite floors
ADVANTAGES
• Cleans without damaging the surface
• No need to rinse if used highly diluted (1:200)
• Can be used with a floor cleaning machine
HOW IT’S USED
Weekly use:
1. Dilute a 25 ml of the product in 5 litres of water
2. Mop floor or clean surface as necessary (no need to rinse)
Special Applications
On very dirty surfaces or for in-depth cleaning, dilute 500 ml of the product in
5 litres of water. Wipe up the dirt and rinse
Stone Cleaner
TOTAL PROTECTION
FOR ALL GROUTS
150m2
WHAT IT’S FOR
• For protecting all grout joints on wall and floor tiles
ADVANTAGES
• Protects the grouts in ceramic tile floors and walls
• Prevents the absorption of stains, particularly greasy ones
• Eases the removal of dirt
• Water based
HOW IT’S USED
1. Apply the product to the grout using the spout in the cap
2. Spread the product evenly with a small brush
3. Leave to dry for a few hours
4. The surface is ready to use
Initial Cleaning
GROUT FILM REMOVER
FOR LIMESTONE,
MARBLE, SLATE,
SANDSTONE AND
POLISHED GRANITE
1:30
50m2
WHAT IT’S FOR
ADVANTAGES
HOW IT’S USED
4. Rinse with water
ACID GROUT FILM
REMOVER FOR
UNPOLISHED MARBLE,
UNPOLISHED GRANITE,
GLAZED CERAMIC AND
TERRACOTTA
1:5/1:10
20/40m2
WHAT IT’S FOR
ADVANTAGES
HOW IT’S USED
Protection
POLISHED PORCELAIN
25m2
WHAT IT’S FOR
ADVANTAGES
HOW IT’S USED
POLISHED TRAVERTINE
& MARBLE
20m2
WHAT IT’S FOR
ADVANTAGES
HOW IT’S USED
in Stone Stripper
GRANITE
10/20m2
WHAT IT’S FOR
ADVANTAGES
HOW IT’S USED
& TUMBLED MARBLE
1 litre
20m2 per coat
WHAT IT’S FOR
ADVANTAGES
• Water based
HOW IT’S USED
IMPREGNATOR SEALER
LIMESTONE
10m2 per coat
WHAT IT’S FOR
ADVANTAGES
• Water based
HOW IT’S USED
ENHANCER FOR
UNPOLISHED STONE
10m2 per coat
WHAT IT’S FOR
ADVANTAGES
• Does not yellow
• Easy to apply
• Wet look
HOW IT’S USED
Colour Intensifier
SLATE
1 litre
20m2 per coat
WHAT IT’S FOR
ADVANTAGES
• Water based
HOW IT’S USED
Routine Maintenance
ADVANTAGES
HOW IT’S USED
4. Rinse with water
Grout Cleaner
ROUTINE CLEANER FOR
CERAMIC AND
NATURAL STONE
1:200
1,500m2
WHAT IT’S FOR
ADVANTAGES
HOW IT’S USED
Weekly use:
Stone Cleaner
TOTAL PROTECTION
FOR ALL GROUTS
150m2
WHAT IT’S FOR
ADVANTAGES
• Water based
HOW IT’S USED
