Discuss how to dot n dab plasterboard in the British & UK Tiling Forum area at TilersForums.com.
GazTech
hi all,if i was doing a splashback and the walls were in a poor state could i dot n dab board onto this and would it be sufficient to hold to the wall properly using this method?? if so what is the type of plaster you use for dott n dabbing?? any help appreciated
No problem kilty, this is an often used method and you can use most adhesives for fixing them. Just make sure if applying cement based adhesive to gypsum skim, then prime it first....Gaz
MrSpoon
ivae allways been told it goes off fast but when i've used it its had plenty of time to mess about with (bedding it in and leveling it wise) tho when it comes to plasterboard i guess im pretty quick at that now so once a bucket full of adhesive is mixed up i soon slap it on the walls without giving it time to go off in the bucket,, says 90 minutes workable time on the bag tho?
Reply to how to dot n dab plasterboard in the British & UK Tiling Forum area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
Hi all. I'm looking for advice regarding the tile becker fitted on the plasterboard. It's...
Hi All , I am trying to build a shower cubicle using the tray in the picture (super heavy ) at...
kilty55
edinburgh
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
