How to identify presence of an earth electrode Discussion ThreadHow to identify presence of an earth electrode Electrical Advice
Hello to all you fine folk out there.
I have a question regarding earth electrodes.
I've had two periodic inspections/EICRS recently, where I haven't been able to locate the earth electrode. I am guessing they are installed but have possibly been covered over by new patio extensions and other ground works. The reason I say this is that in both cases, they are small 3 bed houses. I have identified my neutralising links, and there are 3 other 10sq earth cables at the MET at the distribution boards. I know two are doing the bonding of gas and water.
So I'm guessing the other is going to the earth rods.
Is there a way I can test to find out if an earth rod is installed? I remember a guy telling me a while back to disconnect the neutralising link and perform a test across main L, N and E? If result I'd up around 200M ohms then there is an earth rod but I'm not too sure about all this.
Any help I'd really appreciate
How to identify presence of an earth electrode for the original thread on Electricians Forums
