Discuss How To Tile, Advice & All the questions I asked when i joined in the British & UK Tiling Forum area at TilersForums.com.
Olz
re: Tile Advice - All the questions I asked when i joined - Answered
Replacing a Damaged / Broken Tile
Obviously there are a few ways to go about this, this is how I go about it.
For safety wear goggles and gloves.
Start off by scraping the grout from the sides of the tile in question, use a grout rake, or a fein or similar, the drill 4 holes in the tile, in a square formation.
Use a hammer to crack the tile, gently, no need to go mad with the hammer, remember your replacing a damaged tile not trying to make the good tiles match the damaged one.
Hopefully you will now have 4 pieces, assuming the tile had not lifted already, chisel out the pieces, start in the middle working outwards minimising the risk of damage to surrounding tiles.
Once youve got the bits out, get rid of the adhesive that was behind the tile, being carefull not to take chunks out of the substrate.
Depending on the size of the tile, you may not be able to get the trowel in to apply fresh adhesive to the wall, if this is the case, back butter the new tile, replace, allow to set and regrout.
Oli
Olz
A quick one before I go to bed,
Silicon Tip
Apply your bead of Silicon, having cut the nozzle at 45 degrees, when you've put the bead on, spray it with a weak washing up liquid and water mix, spray your Silicon smoothing tool or finger with the washing up liquid and water mix and smooth the Silicon bead using one smooth motion, leave the washing up liquid and water mix to dry away.
The washing up liquid and water mix should only me made weak, and will stop the Silicon sticking to your smoothing tool and finger making it easy to smooth over without it going all over the place. :thumbsup:
beanz
Berkshire
Can you elaborate on this please Oli? I'm probably just dense, but i'm not 100% sure what you mean!?! Are these holes at the mid points, corners, edges, or doesn't it matter too much?
Great thread BTW, learning loads arlready! :thumbsup:
Reply to How To Tile, Advice & All the questions I asked when i joined in the British & UK Tiling Forum area at TilersForums.com
Hey everyone! Just want to say first of all that I am not a tiler or anything I’m just in need...
Hi everybody, I've taken on the task of tiling my own kitchen, and before I wreck everything and...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
