Discuss Hygrometer in the Tiling Tools area at TilersForums.com.
Yes Alan......spelling isn't my strong point as pdc (spelling policeman) will tell you !!not wishing to be picky either but its a hygrometer you are looking for...unless its for your home brew
What sort of money should we be expecting to pay for a carbide bomb test kit Alan? Don't want to be getting ripped off.amazon.
however if you can afford it go for a carbide bomb kit.they are quicker and much more accurate.
I used 20mm kerdi board, bonded together with kerdi-fix. They take minutes to make. I have 5 and one failed. The floor sweated so much once they force dried it, the unit got soaked.Search ebay for panel mount digital hygrometer and it brings up the exact one that's in the F Ball unit like Impish mentions. That's the one I've used too. They are only £18-£20. I made the body with some high density foam but you can use 50mm insulation board. I've tested them side by side and they gave identical readings
Reply to Hygrometer in the Tiling Tools area at TilersForums.com
