Discuss I have a Problem in the UK Tiling Forum area at TilersForums.com.
JOHNJO14
Thank you all so much for your help with tiling questions in the past.
I now need advice on a Painting issue, it is probably simple but i just dont know how to take off a Paint Roller Sleeve & replace it with a new one.
Does anyone know how i can get the old Sleeve off, does it slide off & the new Sleeve slide on ? ( i have tried to slide it off but it would not budge), or do i have to cut it off with a sharp knife ?
Your help will be appreciated. Thank you,
John
Ajax123
1,213
Lincolnshire
Normallythere are two centreing wheel inserts one either end and the sleeve tube pushes over these. These just slide through the sleeve tube. They should be tight and may well be clogged with paint but should budge with a little bruteforce
Reply to I have a Problem in the UK Tiling Forum area at TilersForums.com
Hello, after watching so many instructional videos and planing, I just can't understand how to...
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results...
I have a Problem
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
