Discuss I just bought the levelling system in the Canada Tile Advice area at TilersForums.com.
L
LM
The cons for this type of tiling is the fact that it is prone to
leaving voids in your work,up to date no one has published
details to this respect.
also how much time does it add to a job.
Using levelling clips or not, ill prepared substates will lead to voids under tiles if not addressed. The clips are brilliant for the SLIGHTEST of adjustment to clamp adjoining tiles level with each other on properly prepared substrates and in that regard do save time. Yes they cost money and do take time to install, but the difference in time taken to achieve the same quality of flatness in comparison as to when not using them is considerable. Personally I think it speeds up achieving that level of finish. If tiles are back buttered on a correctly prepared substrate then they are an advantage!
One Day
They CAN make a "tiler" lazy enough to create voids.
In themselves they don't create voids though.
Used correctly they save the time adjusting levels and tweaking, as well as the risk of adhesive slump.
Used poorly - they can make a spot-fix job go really fast and look great. That is the main risk in my opinion.
Dumbo
This is getting silly lads, if you lay two tiles you'll use 2 straps, 3 tiles you'll use 4. If you lay a long narrow corridor it will have a different ratio than a large square room. 11 straps per mtr is an average for 600x600, chill out!
I know that and I agree with you totally but apparently that needs to be demonstrated to me by some people
Reply to I just bought the levelling system in the Canada Tile Advice area at TilersForums.com
Does anybody else have the issue of joints being opened up when using a tile levelling system...
5K
Hi Ive been browsing your forums over the years looking for guidance for odd tiling DIY tasks...
Hi Guys, I have been tiling since i was 17 (im 31) I have been stuck in my way and to be honest...
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Hello, I'm having problems finding a tiler who knows how to use Kerdi board. I've had a few...
Uk
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
