Guest viewing limit reached
I need some help with Travertine Wall tiles
I've used an orbital sander with a scothbrite pad to good effect.
(Cleaning up after some dodgy tiler!)
This creates loads of dust so wear a mask and seal the doors.
It also eats into the tile surface if you aren't careful but it does take you back to a clean surface, ready to go again.
may i ask where you bought the scrothbrite pads from? would i be able to get them from say B&Q.
obviously the sander i can just hire, just not sure on where to get the pads if i need the, googling seems to find more for normal (rectangle) sanders rather than circular ones which i would presume is preferred.
Dave, just noticed your from Durham 🙂
CTD as in these?
broken link removed
CTD Sunderland
Brooke Street, Sunderland, SR5 1BN
T: 0191 567 1333
F: 0191 567 1999
thanks again for all the help,
don't know where you are but there are ctd's in
team valley/sunderland/darlington/stocton/sheilds rd nw,castle....hope this helps.........
Hi Kev,
I am leaving the liquid on for about 3-5mins then using a scrubbing brush to agitate the material, prior to polishing with a cloth and rinsing with a lot of water.
Randomly i opted to use some sandpaper on a descrete tile and it went from the white you see on the right to a nicer brown colour (when dry). I think that the residue is just too thick and requires something more abrasive to remove it.
Any recommendations if that is the case?
Also is the browny colour correct for white travertine, my girlf and I have differing opinions on that colour they should be, as i feel just cos they are labelled white doesnt stop them being brown in colour.
Really need to find a solution as i am sick of having to go to her mum for a shower lol.
I would use my hand machine and Aqua Mix Nano scrub but you may find it difficult to get hold of. So the suggesstion of the Lithothin cement away and the orbital machine with a scotch pad will probably work. Be careful which colour pad you use and don't use black it is too coarse. You can make your own pads as well by going into any Janitorial suppliers and buying a large one and cutting it to size for the machine that way you will get several out of one pad. If the haze is deeper and persists simply double the pad to make it work deeper.
Good Luck
Kev
Dave, I'm from Sunderland so that was the closest listed for up North.
Kev, thanks again, i'll avoid black.
Try using HG Grout and cement film remover (dilluted) apply for a minute or two then wash off. Then apply a couple of coats of HG natural stone impregnator/sealer. This will help get a 'wet look'
I have tiled our bathroom walls with 10x10cm travertine tiles, then grouted using a limestone grout, buffed the excess grout off and set about sealing.
When you say you buffed off the excess what did you use?
t121anf,
t121anf,
t121anf,
t121anf,
