Discuss I saved a lot of time with this in the UK Tiling Forum area at TilersForums.com.
tommyzooom
1,083
Ireland
I was faced with this dilemma, two feature strips, either side of wc and basin. tiles are 11mm, mosaics are 8mm.Oh and they want 2 silver square trims either side of the mosaics, these are 9.5mm. Normally I would try and put the trim under the tiles as it is too fiddely to bed out both trims and mosaics.
The solution: Make them up the night before
Ready to be fitted
Fitted
The finished article
Richard Edwards
Quality........ I do something similar with thin sheet mosaics when they have to go with thick tiles, I stick them to ditra.....
I keep 6mm lux / cementous board for that issue. stick the 6mm board as a strip to the wall in the gap between the thicker tiles and as long as the main tiles are set at the correct height - 12/13 mm on a 10mm porcelain tile, run the mosaics in a line to fill the gap - bobs your uncle or is he the auntie ?
Reply to I saved a lot of time with this in the UK Tiling Forum area at TilersForums.com
Hi, hope that someone might be able to help. We are currently in the process of tiling our...
hi, wondering if anyone can help, been doing a bathroom with trims everywhere. window, 3 mosaic...
U
Just to be on the safe side i purchased all 20m2 of the wall tiles Wickes had on sale in the...
At what point do you say no to doing a job ? My problem here is this, I get called in to quote a...
Hi not been around as much as I would like to have been lately. Anyway I'm about to tile a...
cornish_crofter
tommyzooom
Ireland
Website
http://www.mcknight-tiling.ie
