Discuss I'm Confused About Priming! in the UK Tiling Forum area at TilersForums.com.
woodie
hi buddy, it's up to you to be on the safe side i know there are addys out there these days which are 'self priming' so you don't need to prime up as for plaster walls, new definately prime because it will draw the moisture out of the addy and make go off too quick, old plaster not necessarily need to prime as it won't draw out the moisture :santa_cheesy:
sWe
There are three general rules when it comes to priming:
  1. Follow the manufacturer's guidelines. If the specs of a particular adhesive says that a particular substrate needs to be primed, then you should.
  2. Gypsum and anhydrite substrates need to be physically separated from cementious materials.
  3. PVA is NOT a primer, and does not belong in the world of tiling. Period.
More on the subject of ettringite, primer, etc... http://www.tilersforums.com/tiling-forum/10603-swes-guides-5.html#post99461
Reply to I'm Confused About Priming! in the UK Tiling Forum area at TilersForums.com
  • Sticky
Ok. Basically am i tilng right/prepping correctly? Full time professional tiler, nearly 15...
benchwarmer
Hi guys. I'm new to this forum and I'm in some need of advice. Halfway through a major refurb at...
Hi all. It's been a while since I've posted due to 2016 being a very slow year, however things...
RDTiling
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
