Painted Plaster
I don't use ready mixed adhesive so I wouldn't know about that. What I do know is, if Done as I said for prep and use powdered adhesive, the next day you cannot pull the tile off the wall.
Don't ever tile on top of paint on a plastered wall, if it's a **** coat then it probably won't come off but any more layers then it must be removed.
Don't just score the surface to get a key as its only minimal contact, remove as much paint as possible & you will be good to go.
Hi Localtiler.
The use of tubbed adhesive(because it is cheap) to remove the paint is a tried and tested method of removing new paint on new plaster,but powdered adhesive has the same desired effect........ie paint will affected by moisture.....be it whether it has a tile placed on it or not.
As for not being able to pull the tile off a wall the next day.......I have been able to take a tile fixed with RS onto a plastered wall the next day quite easily.......even RS doesn't cure fully for 4 weeks.
PS Not meant to come across as short or curt(as is sometimes possible on the internet)
I agree it is always best to get the paint off! I wouldn't tile on any layers of paint or any bathroom paint or anything like that. Only a sealing coat of thin white emulsion.
The trouble with painted surfaces is you never know if it's going to hold or not...
Thank you for all your replies.
I'm going at this one tomorrow and have managed to borrow a steamer so will five that a go first.
There are probably a couple of layers of paint and it certainly isn't onto new plaster.
It's a pity the wall is painted as putting my big spirit level on it, it is very plumb, with no gaps between the wall and the spirit level.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
