Impey Aquadec
F
fez
Hi guys, I was wondering if anyone has installed and tiled an Impey Aquadec level shower tray. I have already installed the tray(including supporting the joists and ply lined etc.) however I am confused, specifically regarding the layout for tiling in order to keep the preformed slope etc. The layout is what I'm concerned about. Do I just tile over the area of the tray to keep the slope and keep the tiling outside the perimeter seperate. Anyone got any pictures? Any information from someone who has successfully completed the same task would be welcome.
There is a bit of a questiom when it comes to shower tray formers because the last thing you want is cut edges under foot.
Personaly if advising on a shower base I would recomend using a mosaic as this will move to your falls However it has been done with 33x33.
You dont set your lines up the same for a wetroom as you do a normal room you use the former / base lines. Lay your tiles around the base dry starting at the corner away from the exposed corner so you end up with an L shape and and all full tiles at the edge of the tray (cut tiles at the wall)
Mark these lines out and off you go
101
Impey Aquadec
Tags Tags
usa
fez,
tiler-101,
fez,
tiler-101,
