Discuss Impressive skill in the Canada Tile Advice area at TilersForums.com.
sand ,lime and cement there is another video by the same guy which tries to explain the mixI'd love to know how that adhesive/sand-cement holds those bricks up without even moving at that angle....
These ceiling bricks are held up as they are in a state of compression, the more weight then the stronger it will be, I'd imagine the outside walls would require buttresses. You would think it would be a weak structure until the last stone went in to place (key stone) but I think the way they are doing it around gradually in a square gives the structure enough strength while it's being built.
Reply to Impressive skill in the Canada Tile Advice area at TilersForums.com
