Discuss Inscreed Electric UFH in the UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
The UFH should be fully commissioned and run before tiling. If there are no joints in the screed it is likely to crack on heating. If it does you might want to consider uncoupling. Generally the heating should be controlled by floor stats in preference to room stats. The screed should be clean dry sound and free from dust and debris and primed using I would suggest a simple acrylic primer followed by if needed a flexible cement based smoothing compound. This should be left for 24 hours minimum before applying tiles with a flexible cement based tile adhesive. It is not usually necessary to re prime the top of the smoothing compound but some do and some dont. I personally would not unless it is dusty due to over watering.
Reply to Inscreed Electric UFH in the UK Tiling Forum area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
