Discuss insulating a flat roof ceiling ?? in the British & UK Tiling Forum area at TilersForums.com.
Alan.P
No it wouldnt , sometimes its easier to keep them up as gravity doesnt take over
its not done like that because its time consuming cutting each bit to length
Exactly, not wrong just time, it might be easier for you that way if your working on your own, then wedge them in, otherwise, some sort of retainer might be needed.
Ajax123
1,213
Lincolnshire
I just got some advice on this from building control. They said if it is unvented then go in between the joists but leave an air gap then place a vapour barrier on the warm side before plasterboarding (or what ever)
If it is a vented roof then there are actually regs covering the size of air gap and the depth of insulation and you would probably have to go with a rigid board insulation rather than a mineral wool. You still go with the joists. For added insulation I was told to place a further 25mm of polyurethane (cellotex) board on the underside of the joists. Tape the joints and this acts as the vapour barrier. The plasterboard as normal.
I of course am ignoring all of this advice and doing my own thing.........
Alan.P
the reason i was thinking of going across the joists is that the rolls of insulation are in a bag to avoid all the nastiness associated with fibreglass and they are 5 metre rolls , the room is 5 metres long ...............
Lost me there Paul, are you saying ypu want to follow inbetween the joists ie follow the full 5 m with the 5m roll or cut into strips of 300mm +/- ?
Alan.P
it is joisted narrow , i want to use the 5 metre roll across the joists along the length of the room if that makes sense :lol:
Nope, I'm having a blond moment, like this ???
Reply to insulating a flat roof ceiling ?? in the British & UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hello, we’ve just had a bathroom tiled. A 1.5cm gap is at the top, between the tiles and...
Jay jean
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hello, first post, asking about career change and possible entry route into the industry. I know...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
