Discuss insulating a flat roof ceiling ?? in the British & UK Tiling Forum area at TilersForums.com.
Alan.P
i was going to put the insulation above the joists and the boards below the joists if that makes sense :thumbsup:
Starting to now, the gap above the joists is for air circulaion as stated by Ajax, I'm not clued up on any of that side so can't comment, I see what your wanting to do, whether it's acceptable or not ???????
Alan.P
not you , it is me , it is a false ceiling below a ceiling !!! :mad2: :mad2: :mad2:
:oops: we're getting there :lol:
forget that post up there :D
I now have no idea lol
So you have a ceiling, and have now put a false celing in ? and want to insultae that, can't see why you can't but like I said, I'm not clued up in that area .... sorry :D
Tecnik2000
Just sticking my nose in here, it makes little or no difference if you can go at 90 degrees to the joists & maybe better as there are no joins or cutting to achieve the insulation required with out jeopardising your uv values. I'm sure you can devise a way of supporting the insulation adequately using battens,strapping or just laying on your sus ceiling...
paulyoung666
now he tells us
yes you can, ensure theres an air gap above the insulation to allow free passage of air otherwise you will have condensation problems
thanks for that , with the joists i go then as i have condensation problems now , due i suspect because no insulation was put above the original ceiling :furious3:
Reply to insulating a flat roof ceiling ?? in the British & UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hello, we’ve just had a bathroom tiled. A 1.5cm gap is at the top, between the tiles and...
Jay jean
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hello, first post, asking about career change and possible entry route into the industry. I know...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
