Hi,
We have been supplying and fitting these boards for over 8 years now and never had any problems with them. We have had them tested with granfix, altra and ardex adhesive manufactures and they all confirm they are suitable for use with their S1 rapid or
standard set adhesives. You should however avoid the use of mosaic tiles over these boards unless a 6mm layer of suitable levelling is first installed over the boards / heating as this will spread the load of the individual mosaics which is normally done by the
tile.
The standard insulations boards, (no
cement covering) are typically far cheaper our retail price is under £4 including vat where as our marmox equivalent price is nearer £9 inclusive. Typical XPS boards also provide more insulation than the marmox type boards as they are100% insulation rather than marmox which has a
cement coating either side which reduces the insulation ability of the board.
In short if you are installing the insulation over a stable solid floor and use a 1part flexible s1
tile adhesive to fix them in place the XPS boards (not
cement coasted boards) are cheaper and will provide a better insulation level than marmox type boards. If you would like to screw the boards down or screw the boards to the wall such as when tanking a wet room then use the marmox type boards. Marmox type boards have like mentioned the
cement layer that has a reinforced fiberglass mesh within it which is there so the fixing disce locks into the mesh and spread the load stopping the board ripping off the wall.
I hope this helps.
Andrew Knight.
