Discuss insulation Quinn therm 50mm in conservetory in the British & UK Tiling Forum area at TilersForums.com.
Trevor Harmer
Hi I'm in the process of laying ufh took up the old tiles to find the screed crumbling away so I have had to removed all the screed back to the concrete base. My dilemma is this. I have got 50mm Quinn therm QL to make up the screed base but this seems to be not so ridged if you kneel on the insulator it leaves your knee print! I will be laying 500x500 tiles what would you suggest laying the ufh over this and self level or add something ells on the insulator before self levelling?
Trevor Harmer
In hindsight 50 mm marmox or wedi would have been spot on but I do not have that option the insulation is already fixed to the substrate I am hoping to resolve this by the morning I appreciate you taking your time on this Dave do you think my suggestion will work in theory putting the hardy backer fixed to the foam is the same as a cement facing
board?
DHTiling
OK...Well it's just the compression issue then...if you thinkit will be fine then as i cannot see what you can it's hard for me or others to say yes deffo go ahead....might be best to lay a hardi board on it and then see what compression you have....this thing is with marmox and wedi boards there compression rates are good but seen as i have not come across and seen the quinn then thats hard to advise 100%.
DHTiling
Trevor...In the morning phone a few adhesive tech lines and ask if they have a slc that will cope on top of the quinn board..hardi is normally glued and screwed, so again get confirmation on this option..
Last thing you want is a failure and this is a scenario i have not come across...good luck mate.:thumbsup:..let us know the outcome plz.
Reply to insulation Quinn therm 50mm in conservetory in the British & UK Tiling Forum area at TilersForums.com
Hi, I have decided to install underfloor heating in my hall and kitchen the current floor is...
Hi, This is for a bathroom (including a bath). I have a buildup of timber joists / 22mm ply /...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
