AlexJones
Hi
Can you please let me know if a product like Schlüter DILEX-EKE or equivalent internal profile trim is generally visually cleaner than using Silicon? I assume 3 way internal corners could look messy if not cut correctly but was wondering if I should go for some sort or trim like this for where my floor joins the walls, and corners etc? Funny but I have never seen one installed and have only ever seen sealant used for internal corners etc.
Also assume if everything has been correctly waterproofed one could use trim like this for internal corners in a wet room, or is it not advised?
