Discuss Is Ditra an overkill on concrete with ceramic tiles? in the Tiling on Underfloor Heating area at TilersForums.com.
AndY mac
Hi Dave. Check for deflection if really bad walk away there are some horrors of floaters up here. If you must do it the way I did one a while back was 10 mm marmox glued and screwed heated then screeded then ditra tiled with a decent 2 part. I was back at this property to do there bathrooms and all was good but it's a gamble. I only did it after stressing if ther was a failure I would not be held responsible. The garuntee only lasted till I walked down there path and into the van.
bigdave1903
483
Aberdeen
I
If it's floating it won't have joist just chipboard over kingspan.
m
I'm confused now. Architect definitely said the joists were 200mm apart. Is a suspended floor the same as floating floor? This pricing malarky is harder than I expected haha.
Stef
I
m
I looked again & noticed that you said the joists were 200mm apart, strange make up even if it's a suspended floor, normally 400mm apart even if they are trying to strengthen the floor knowing its to get tiled.
bigdave1903
483
Aberdeen
Pull a bit of carpet back and look for fixings if there are none then it's a floating floor which is just chipboard over insulation (kingspan)....not screwed or nailed down to joist..
It's a new conservatory so its just chipboard down. There were plenty screws in the chipboard. Thought I was going to have to get nanolight adhesive to stick to all that metal haha
Stef
I would go back to the architect & ask him again what exactly the floor make up is before I went any further.
It sounds like a suspended floor but those joists are very close together.
Better news for you as at those centres it should be rock solid.
bigdave1903
483
Aberdeen
Perfect thanks. Will do.
Reply to Is Ditra an overkill on concrete with ceramic tiles? in the Tiling on Underfloor Heating area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
Hi everyone, With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a...
Beginner DIY Tiler, I'm contemplating drilling (with ceramic tile carbide tipped drill bits)...
Hi all, Was looking for some advice in regards to micro-cracks appearing on the SLC on top of...
Underfloor Heating Trending Threads
Aberdeen
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
