Discuss Is the porridge too hot, too cold or just right. help appreciated. in the UK Tiling Forum area at TilersForums.com.
jwatson
The job is local and is less than 5 miles away.
12.5 m2 kitchen floor to be tiled with ceramic 400*400
splash back to be tiled 100*100 varied pattern.
prep work to be done.
rip existing wall tiles off. sink electrical back boxes X 4, patch + prime walls. spf.
rip vinyl flooring up. screw down any loose boards if any. (deflection test done little/no movement)
fix hardie using spf and screwed.
weber spf to be used on floor.
white star on kitchen walls.
bal grouts. grey floor/white walls(microban)
straight white trim only. no 3 ways ect.
all in £914 ??
Reply to Is the porridge too hot, too cold or just right. help appreciated. in the UK Tiling Forum area at TilersForums.com
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
Posted a couple of times for advice a few weeks back, the outcome of which was to scrap my plan...
I was quoted over £4700 (inclusive of VAT) to rip out and replace my bathroom. This does not...
7K
First post on this forum and unfortunately its not under good circumstances. We have built...
14K
Reggiethethird
F
Hi all I'm tiling my second kitchen, and just wanted to check in with you all that I'm doing it...
Futuregrout
F
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
