Discuss is there a real solution to chipping tiles? in the UK Tiling Forum area at TilersForums.com.
Peter A
I have purchased Porcelanosa Shine Dark 1000 x 333 wall tiles and installed them very successfully ....up till this point....but due to the fact I had no corners to frame. Now, due to window and boxing forming a recess i do have corners to frame plus cuts longer than 500 so i am in a dilema! I can snap them very cleanly but as soon as they set eyes upon my tile cutter they chip. I purchased a new Erbaurer 750w; 180 x 22.2 disc and with the standard blade, not pushing too hard and letting the disc do the work, etc, etc, they still suffer the same problem.
So after reading many many of the posts on here and the advice that is given I am about to purchase a quality disc to see if that resolves the issue. From what I can see it boils down to a few so the question is, which one .....from Montolit is it CPS, CPF or go the whole hog with the DNA, Rubi CPC 180 or a Marcrist blade??
I am not a tradesman but have been in the building trade all my working career so will do most things successfully with the right tools after watching, learning and having the confidence......apart from plastering that is!! :)
Now I am stumped, help!!
Am I being too picky or is there a solution??
Perry
this should sort it
http://www.tilersforums.com/members/pjc-albums-pete-picture16846-corner-cut.html
Peter A
Thanks for all the advice, in answer to some of the other questions above, it is the long thin high gloss ones, it is the glaze not the tile thats cracking, I may have to buy a longer manual cutter though!!
I will have some practice runs.
Hopefully, I can do some more tiling rather than looking aimlessly at it then going to cut the grass!! :)
Thanks again all
Reply to is there a real solution to chipping tiles? in the UK Tiling Forum area at TilersForums.com
Hi I'm currently trying to tile my Cloakroom - have purchased porcelain tiles and a wet saw...
Hi, I am trying to cut 600 x 600 porcelain tiles diagonally corner to corner on my bridge saw...
5K
Concrete guy
Hi All I'm looking for some advice from the experts and hope you can help. I've just had a...
Can anybody recommend a cutter that will produce very good edge cuts on 10mm very hard porcelain...
9K
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
