Cutting porcelain tiles diagonally
Thank you ATS, I only have three tile edges to do so I may look at using a hand pad. Are you able to provide a product name and part number?
Kind regards
Stuart
Kind regards
Stuart
I can't provide links back to our website on forum (advertising etc) but some of the other members will be able to point you in the right direction.
Thank you guys, you’ve been very helpful. Is there one grade of hand pad that will do the trick to create the chamfer or will I require multiple grades?
Kind regards
Stuart
If it's very dense stuff you may need two pads, otherwise one is enough.
#50 to cut it and #200 to finish it.
If it's not super dense a single #100 may be enough.
StuVin,
Concrete guy,
StuVin,
Concrete guy,
