Is there an easier way ?
L
Leatherface
Chaps, don't ever profess to know it all.
Have quoted a 35 sq m kitchen and dining room floor.
They have a massive triangular island unit in the middle. I have quoted them £20 per hour for dry laying & setting out the tiles around the island, prior to laying.
Don't know any other way of making sure both sides meet. Would never ever usually dry lay, but don't see any other solution ?
What's your view ?
I tend to dry lay the first rows around the island as well..but making a staffing rod helps as well...centre all points around the island then ping lines to these points and use your staff rod to work the cuts out....
chalk lines and basic maths :yes:
If your chalk lines are a "mm" out at the start of a 2.5 x 2.5 . 3.5 metre island you are f***ed
You need to be millimetre perfect here.
Don't just spout off " chalk lines and basic maths" - if you are that confident you can do it then give a proper explaination. I am asking for help here, not just textbook comments.
In my experence, chalk lines are not ever 100% reliable.
I use a rubi square and straight edges usually, but the nature of the kitchen, with narrow walkways does not able me to use them !!
grid the floor and tile within the grids say 2 tiles and two grout lines are 600 squares of 600 square have had guys tiling diffrent rooms at the same time and meeting up as you would around a swimming pool Pete
i am not spouting off im dyslisix takes a while to type in english
i find a rod is not as good as a tape keep the tape on your datum all the time 60 +60 = 120 then 180 then 240 ect then 345 it as large as pos if you keep your chalk lines short it will not wonder Regards Pete
your down my way soon let me know when i wiil show you if i can not working till the 10th might be able to leave my guys on the job on there own i hope :grouphug:
Leatherface i tile shop floors average 800 mts its all done with chalk lines and 345 so the square i use 4.5mtrs 6 mtrs 7.5 mtrs just maths not from school mate :lol:
Thanks, never been that good at maths.
I usually set out using a staff, straight edge and rubi square.
When you say grid do you just mean like finding the centre of the floor and then seperating it into equal sections etc?
Sorry to sound stupid but i'm not that experienced......... I just tend to seperate my area into equal areas and then dry lay my first couple of rows......
Gaz
Hi Gaz no you can grid the whole floor in 600 squares ( the size of the tiles & joints ? ) if you need to or less say in case of a island you have a 2 datum lines one 90 degs to the other 6x300 tiles 1.8 of your datum so you make a 1.8 square box around the island if you keep one tile against the chalk line and the other side of the box a grout joint away as i would around a swimming pool be easy to show someone that put it in writing :yes: Pete
Tags Tags
there usa
Leatherface,
Perry,
Leatherface,
Perry,
