Discuss is there such a thing as mechanical fastenings for large/heavy stone tiles in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Julian 'Farmer' Bonsall
Thanks for the feedback.
What did you tell them the temperature range is?
I have a wall the opposite side to an Aga and its chimney (paraffin burner) to do in the near future. The wall gets warm but I logged the temperature (you could use something like Mini Digital LCD Thermometer Temperature Hygrometer Probe Indoor Room Office CE | eBay - https://www.ebay.co.uk/itm/Mini-Digital-LCD-Thermometer-Temperature-Hygrometer-Probe-Indoor-Room-Office-CE/152628487236?epid=15005621374&hash=item23895de444:g:QZcAAOSw2kZZbbNA&autorefresh=true). The maximum I saw was around 64DegC.
Anyway my project is different but the attached document may be helpful. It states a temperature upper limit of 90Deg C like most of the Mapei products [Maybe most tile cements have this property I have investigated] The Keraflex Maxi S1 states the highest bond strength after heat ageing but not for natural (its what I think I will use). The Keraflex may work. Anyway I don't know how hot your boards get or if you need a material to insulate the tiles from the heat of the chimney.
I have attached an Ardex document which I found useful for my project.
[Diy'er ]
  • 103_keraquick_uk-13.pdf
  • 74_keraflex_maxi_s1_hk.pdf
  • tb111.006_tiling_adjacent_to_hearthandfireplaces.pdf
Rosco100
578
Inverurie
I’ve done them over the years and never had any problems. I’ve used a bagged S1 adhesive like Weber low dust spf and added in some Weber ad250 additive and grouted with a flexible powder grout. Primed walls first with acrylic primer diluted then neat and never used mechanical fixings unless over 3 metres. Notch the wall aswell as small notch the back of tiles.
Ditto
Could you use a mini saw such as this works one (has bevel capability) or a grinder / dremel to make the incisions for the wall brackets?
Reply to is there such a thing as mechanical fastenings for large/heavy stone tiles in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Best Tile Adhesive for Wall and Floor Tiling Annual Poll 2024 (TF) Best Tile Adhesive for Wall...
Hi there, We have red quarry tiles in our indoor entrance hall and my wife would like to paint...
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Tile Buying Popular Threads
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
