Discuss Is there such thing as too many substrate layers? in the Canada Tile Advice area at TilersForums.com.
Hi I have been browsing these forums for a while and have picked up lot of useful advice.
There will be 7 layers to my floor (not including Adhesives, seems like a lot!)
Joists/Noggins
18mm Ply
6mm Hardie Backer
10mm Warmup
Electric UFH
SLC
Ditra Mat
Tiles
I’m a Diy’er tiling my first floor but have done lots of research trying to get it right.
It’s a small upstairs bathroom in a Victorian Terrence.
I ripped up the floor boards as they had large gaps etc.
The beams are 400mm centres, I put in 3 rows of noggins at 610mm centres where the board join.
I laid 18mm Plywood (DIY stores didn’t do 24mm). Sealed back and edges, Glued and screwed to beams / noggins.
6mm Hardie backer board fixed with Mapei Kerquick S1 (Hardie recommended non flexible but my local screwfix was out of stock so used S1) and screwed at 150mm all over, fibre taped and adhesive over the joins.
This is as far as I have got so far (the floor feels nice a stiff when I jump on it) ... but the plan is:
10 mm Warmup boards stuck down with Mapei S1 and screwed with large washers. ( I got these boards for free or I might not have bothered).
Nass board underfloor heating kit (Laid by myself multimeter testing as I go and terminated by an electrician)
Bostik Cempolatex Flexible self-levelling compound (mainly to protect the wires from my bad trowelling)
Mapei S1
Schluter Ditra mat (Because I’m scared the gout will crack if I don’t, will it?)
Mapei S1 with Latex added
200mm X 200mm Ceramic tile with a 3 mm grout line Bal grout with Latex added. (Also using vitrex LASH system to hopeful get 0 lippage on my first try at tiling) going to be cutting with a wet tile saw.
I’m doing all the Adhesive will a 6mm square notched trowel, is this ok?
Is there anything obvious I have done wrong?
Will all these different layers interact to cause any kind of weakness or should I be ok??
Boggs
1,118
Uk
You could have saved a few quid and just glued and screwed the 10mm warmup boards to the ply floor, thin coat of slc and then tile.
Personally I would put heating on the Hardie and slc over and tile.
I would take the Vitrex lash clips back they are not the best and will probably cause more problems than they solve imho.
I just checked and they are porcelain tiles not ceramic!
these: Brasserie Porcelain Paix Tiles | Artisans of Devizes - https://artisansofdevizes.com/product-collections/exterior-stone-porcelain/brasserie-paix-porcelain/
So should be fine with ufh then. Few
(I wasn't planning ufh when I bought the Hardie backer but added it in last minute as a nice luxury for only £70)
I will try the tiling without the Virtex clips and only use them if I struggle to get them level then, £20 worth of returns possibly, I just want to get it perfect after putting so much time and money in!
Thanks for the advice/reassurance guys.
Boggs
1,118
Uk
I hope those tiles are not as “sizey” as they are in the picture!
If you want to use levelling clips then buy some from Pro Tiler, down there:handpointdown:, or eBay.
You want ones with a thin flat bottom.
I would suggest buying the 1mm versions as they break easier when removing and using normal spacers for grout width.
When you knock the clips out kick them along the grout lines otherwise you run the risk of chipping a tile.
Reply to Is there such thing as too many substrate layers? in the Canada Tile Advice area at TilersForums.com
Bristol
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
