Discuss Is this marine plywood? in the Australia Tiling Forum area at TilersForums.com.
Thank you all for your replies!
I brought this from travis perkins
I cannot see any BS1088 stamp mark on the plywood but the invoice says marine plywood and BS1088
The size is 2440 x 1220 x 18
I paid £39.18 + vat
I phoned buildbase first and they wanted £57 + vat
I will call travis perkins tomorrow!
No great need for marine ply then, i use WPB 18mm for that which i get from a timber merchants and not a diy store, usually sets me back about 25 plus vat and is good quality. If your worried about leaks then just waterproof the floor. Personally i don't but i do prime the underside and any exposed edges of the ply. Tank the walls and the corner join between the wall base and the floor before you fit the tray, make sure the floor is flat and level and is solid, put extra noggins between your joists especially under the tray area.
Spoke to travis perkins
Will go and change it for marine plywood next few days
I checked on the phone and they said there marine plywood has the BS1088 stamp.
Thanks everyone for your help!
Reply to Is this marine plywood? in the Australia Tiling Forum area at TilersForums.com
