Discuss It must be monday.... in the UK Tiling Forum area at TilersForums.com.
stusgsx
Turned up to this job this morning. Customer has "tanked" the room with N&C wet room kit but the membrane has not been stuck to the floor at all and then it has had warmup boards stuck on top badly and big bits missing and look at the overlapping wires. Nice! Told them its got to come up.
stusgsx
Yep!
The red membrane is not stuck down at all. I could pull the whole floor up if I lift the membrane.
The thermal boards have been slapped down roughly and not supported in the corners and are lifting with and without the membrane and then we have the ufh which will surely burn out if left like this anyway.
I'm cracking on with the walls today instead
John Benton
1,138
Leeds
They should have read my UFH step by step installation guide!
Sent via Tapatalk for iPhone
They should Bri, it clearly states, 'MAKE SURE YOU OVERLAP WIRES AT REGULAR INTERVALS' so as to cause maximum damage and ultimate failure of UFH. Doesn't it say that on every install manual :mad2:
stusgsx
OK little update!
Apparently the sparky came round last night and said there is nothing he can do about the wires overlapping and that it will be fine!
The membrane has been taken up in the shower area and stuck down but it's probably not waterproof now.
The rest of the floor has been left unstuck oh except for I now have a section of 12.5 pb put in the gap where there was no warmup board!
I've told them I'm not guaranteeing any of the floor and they said that's fine.
Am I doing the right thing or should I refuse to do it?
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
The underfloor heating wot be fine with cables overlapping. And water + electric? I'd rather not guess the outcome myself.
I would refuse to do it on the grounds that it's been prepared really poorly. Surely only a days work to put it right?
Sent from my iPhone using Tapatalk
Reply to It must be monday.... in the UK Tiling Forum area at TilersForums.com
  • Sticky
Hi All First post long storey short had arranged for someone to re model my bathroom on the...
Hi Ive been browsing your forums over the years looking for guidance for odd tiling DIY tasks...
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
