Discuss Just a few questions?? in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
The tiles are 600 x 300 so would you make it the size of 1 tile? I did that on my first job under a sink but it was ply....I cut a notch out the size of a tile minus 25 mm all the way around put 4 battons around the hole so that i could screw magnets on and then like you said siliconed it and it looked great...can this be done with hardiebacker??
YES monty with the right prep of the panel anything is possible..........even using the mirror screws in each corner and having a fully removable panel is possible.....which ever is going to look the neatest.....:thumbsup:
Turkish
Price sounds roughly right IMO. As for cutting round a toilet i cut a piece of lining paper the same size as a tile then using it as a template put it where you want the tile to go and crease the paper round the toilet edge and then draw along the crease with a pencil. Cut out the shape and transfer this to the tile. Worked great for me recently.
Turkish
DHTiling
I don't use them monty as they just collect all the crap etc..........and if a bath has that much movement( in pic ) then it needs sorting before tiling.......:grin: ...
A nice neat Silicon line looks better every time IMO............:thumbsup:
but if you are going to use one then use these from sealux........ http://www.sealux.com/
Reply to Just a few questions?? in the British & UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
