garfield59
Hi everyone. I've been looking at previous threads and got some useful tips but thought I'd take the plunge and join.
At the moment I'm tiling an alcove which will eventually contain a WC and the two end walls are not flat. If I hold a straight edge across each wall the centre is "dipped" 6 to 10mm. Bearing in mind the walls are only about 900mm across, the dip is quite obvious. I was therefore going to plaster the "dipped area" and then when it's dry, coat the whole wall with a 10% PVA mix before fitting 150mm square ceramic wall tiles - nothing fancy. Does this sound okay?
Thanks to those of you who have already helped me without realising it as I read the earlier posts!
Garfield
Garfield
