Discuss kitchen floor 2 substrates in the British & UK Tiling Forum area at TilersForums.com.
ace ventura
Hi All,
Just been to measure up for tiling a kitchen floor through to utility and cloakroom. all in all about 23m2.
problem is that the utility, cloak and half the kitchen are concrete floor really uneven and sloping away from the other half of kitchen floor which is t&g floor boards. house is very old but floorboards are really solid with no noticable movement.
question is what is best method to
a; level all surfaces
and b; tile onto both substrates and with what adhesive
customer has indicated tiles will be either ceramic or porcelain.
david campbell
Hi All,
you will need to overboard the t&g so maybe using 6mm cement boards would be the easiest way to go about this,levelling it all!
would use flexible adhesive and grout and would use an expansion joint between both substrates
Reply to kitchen floor 2 substrates in the British & UK Tiling Forum area at TilersForums.com
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
