Discuss Kitchen Floor Advice Please in the British & UK Tiling Forum area at TilersForums.com.
cococay
Hi there,
I am a new member and want to ceramic tile my kitchen floor 15 sm, I have done a fair bit of tiling both for myself and other people but never floors, after reading advice on the net I seem to be a bit bogged down, this is my understanding.
1. fit min 12mm ext ply to floor and screw down every 300mm (But do I prime the chip board or just the under side of the ply or both and with what, acrylic primer?)
2. should I leave an expansion joint/space around the perimeter of the ply (as you do with laminate flooring to allow movement), cos if I don't won't the ply rise if it can't expand.
3. What is the best adhesive bal fastflex or bal rapid set flexi and do i need to use balbond.
4. What is the best grout to use, bal wide joint or bal flex and do i need to mix GTI with the correct choice.
Any advice would be appreciated.
CLAYS TILES
Hi there,
hi m8, 1st Q, ru tiling onto wood or concrete floor?
if your on concrete floor use bal rapid set & wide joint grout!
if wood floors use flexi,
GazTech
Hi there,
No need to prime the chipboard....screw ply every 200mm ...leave 5mm expansion all round perimeter and 2/3mm between boards.Rapid or sinle part flex will be ok but only guaranteed by supplier if 18mm.Two part fastflex would be my choice...standard wide joint grout of chosen colour with GT1 polymer....Gaz
GazTech
Hi Gaz,
Re your comment regards the trade account with Topps, how do I get one, as I previously said I have done a fair bit of tiling both for myself and other people but tiling is not my only source of work, joinery etc. ...Coco.
See what ya mean CJ, Ouch.
Fetch 2 recent reciepts for stuff you have had recently from suppliers...with their vat reg number on it and Topps will register you coco.........Gaz
Reply to Kitchen Floor Advice Please in the British & UK Tiling Forum area at TilersForums.com
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
