E
ern
Hi everyone.
I am planning to re tile my kitchen floor and walls. Walls not a prob but need some help with the floor. Firstly I should say the tiles we will choose will not be expensive because in a couple of years time we will be knocking through and extending this part of the house, however, at the moment the tiles are coming away from the walls and the floor tiles are cracking all over the show and the whole thing looks awful.
Half of the kitchen floor is floor board and half is concrete. Whoever tiled previously has only dot and dabbed the tiles and has done so directly over the floor boards hence the cracking I guess. I'm hoping these should come up fairly easy without too much damage to the boards. The concrete half sounds as if they are more solidly fixed although there are some hollow spots.
My question is what would the best way be to prepare a floor consisting of floor boards and concrete. Hopefully if the levels between the two are not too bad I was hoping that I could fix cement board down if this was possible. If not could I ply the whole lot out using screws and plugs in the concrete. I dont want too much of a height difference because the threshold of the back door is quite low.
Thanks for your help.
Ernie
Ernie
