Now im confused gaz.Do you recommend laying ply first before tiling the floor or just direct fix onto the t&g floorboards with 2 part flexible adhesive ?
Direct with 2 part if your floor boards are sound enough, obviously any creaking or loose boards need to be secured and any rotten ones replaced. If the floor has lots of movement then overboard to strenghten it with 6mm ply or 6mm backerboard then use 2 part....Gaz
BAL Fastflex Powder & Liquid
A two part, rapid-setting, sulphate-resistant, water-resistant and frost-resistant floor
tile adhesive and isolating, anti-fracture underlay, suitable for use in interior and exterior locations. Suitable for fixing ceramic floor and porcelain tiles and mosaics (including fully vitrified), dark natural stone and slate. Suitable for use on
tile backer boards, glazed tiles, concrete bases,
cement:sand screeds, tongue & groove floorboarding, plywood overlay, floating plywood/chipboard floors, ceramic/quarry
tile/terrazzo/hard natural stone bases, vinyl tiles/sheet, mastic asphalt, steel, glass reinforced polyester (GRP), steel and galvanised steel. Conforms to BS EN 12004, Type
BAL Wide Joint Grout
A water-resistant, frost-resistant
cement-based powder grout designed for grouting ceramic floor tiles, mosaics, quarries etc. Also suitable for use on walls. Not recommended for soft glazed wall tiles, or tiles with metal decor or lustre. Suitable for use in interior and exterior locations in both wet and dry conditions. Suitable for swimming pools. Conforms to BS EN 13888, Type C, Class G1.
NOTE: The physical properties of BAL WIDE JOINT GROUT can be enhanced by the addition of BAL ADMIX GT1. The polymer admixture imparts flexibility, increases adhesion and reduces the water permeability thus widening the application possibilities of the grout, with a classification of BS EN 13888, Type C, Class G2.
BAL Admix GT1
