Discuss Kitchen splashback preperation, priming and adhesive advice required. in the UK Tiling Forum area at TilersForums.com.
Tracser
Hi All,
I will shortly be tiling a splash back around the perimeter of my kitchen using 50mm x 400mm ceramic tiles (8mm thick) upto a height of 200mm from the worktop. The walls are plaster skim over render in good condition but with a very slight dip over a short distance and are painted with emulsion at the moment. I was thinking of criss cross scoring the area to be tiled but was wondering if I should use an appropriate primer aswell?
Can anybody recommend whether to use a primer and if so which one? Also some advice on a good quality adhesive would be very helpful. I have a 6mm notch trowel (somewhere in my garage) to apply it if you guys think this is suitable?
Many Thanks
Reply to Kitchen splashback preperation, priming and adhesive advice required. in the UK Tiling Forum area at TilersForums.com
Hi all, I was hoping I could get a little advice. Currently doing a bit of tiling in the...
Dumbo
Ok, strange one. My customer was advised to chalk his walls. He has removed the old tiles and...
Hi folks, new to the forum and I'm a DIY novice with no tiling experience to speak of. Been...
5K
WetSaw
Hello, Could someone explain me what is splashback tiles kitchen? One of my clients requested...
I
question of the day :) kitchen splashback to be tiled. guess what are those designs square and...
7K
Time's Ran Out
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
