mike1979
I know this has come up loads before but I need advice please as I can afford any mistakes my name must remain perfect it's not that I can do the job it's just I've never needed to do it as I've always done new builds ok now the defence is done as I said in a previous thread I have a bathroom floor to do a previous tiler nailed 3 mm ply on the floor boards and the floor faild he also used rapid set !! I plan on using cement boards but can only get hold of knauf aqua panel cement boards and at a great price will this do the same job as hardi boards ?? And as I said if I make sure the plank style old floor boards are down fairly solid will that be good enough I plan to use latex primer and a good flexible adhesive and grout thanks all oh forgot to add will plaster board tape on the joints do the same job as the cement board tape
