Discuss large cuts in 60cmx60cm porcelain in the British & UK Tiling Forum area at TilersForums.com.
tiler burden
can anyone help regarding this one.
i was in porcelainosa today and as i walked in the showroom, there was a section of 60cmx60cm polished porcelain tiles and in the middle was a large 2 meter circle depicting a compass north-south-west east circle cut out in the middle.
the tiler had obviously cut out curved sections of the 60x60's but my question is, how do you cut large curves out of porc..the edges were really clean and smooth.any tips or advice
cheers
ed
tiler burden
sorry mate not the feature , i mean the 60cm x 60cm polished porc field tiles that it fitted into...
i take it he would have laid the feature pre made circle on top of the laid out porc tiles then drew a circle around so that it transfered onto the tiles, but what method would have been used to cut out the curves to make the circle?? reason i ask is because the edges where really smooth and accurate for a wet saw. unless he used a scribe to swing the curves and a combination of a wet saw to reduce the sections, finished off with nippers...any ideas mate
Deleted member 1779
I recon Dave might have a point. Could be Water jet cutting
Did your compass artwork sort of look like the above??
A water jet company do features in tiles - See the wavy pattern below in the blue and white tile
Our core cutters will only go to a max of 125mm so beyond that its water jet cutting.
One Stop Water Jet
Reply to large cuts in 60cmx60cm porcelain in the British & UK Tiling Forum area at TilersForums.com
Seeking ideas for filling in a cut-out section of a porcelain tile floor. I removed a display...
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
6K
Hi I have a 900 x 900 shower enclosure that was showing some dampness through the grout joints...
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
    • Winner
Hi guys, I've just started a job today with a 60x60 glazed gloss porcelain cararra effect. I'm...
8K
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
