Discuss Large tiles for a kitchen splashback? in the UK Tiling Forum area at TilersForums.com.
N
N!ck
The other half is adamant that she wants larger tiles for the splashback I am planning on doing this weekend as she wants minimal grout lines. I have had a look online and cant really find much in the way of inspiration. I know the norm is to use smaller sized tiles but was wondering if any one here had any examples of using larger tiles and it looking either great or not too clever.
We have gloss black units and are looking at possibly using a light cream coloured tile.
Any opinions / pics welcome :)
kilty55
1,113
edinburgh
i have used a few bigger tiles
the best look i have found is the bigger the better...most splashbacks in height between worktop and cupboards are 500mm ish so a 600 by 600 tile can look good as its 1 solid peice fitted with 1 vertical grout lines
the down side is that your sockets can sometimes odten end up being plunge cuts
looks good tho imo
i also have used ones about 300 by 250 and i didnt like that effect
Aspect Tiling
303
These are the largest I've used on a splashback if this gives you an idea.
And this was a job I did last week.
Cheers
Pete
N
N!ck
Hmmm... she may get her way after all then. Just as she has with the worktop, the cupboards, the floor and the walls!
Bolter; that looks pretty good, thanks for the pics :thumbsup:
The only problem I see now would be having the weight of the tiles on the wall. They are plaster/skimmed plasterboard which obviously could not take the weight of heavy floor tiles (20kg-28kg/m2 depending on the plaster used I believe?).
doug boardley
just because they're large format doesn't mean the weight per metre is any more than smaller format tiles
Reply to Large tiles for a kitchen splashback? in the UK Tiling Forum area at TilersForums.com
Doing a kitchen remodel and all is complete except for the backsplash. The kitchen previously...
Grouting my shower walls in a few days. I tried to do everything by the book, which I did. Water...
Hi all. I've been asked to tile over an acrylic splashback in a kitchen with 60x250on tiles. The...
TF Group Please Join
