laserlevels ???
roadking
Need some help here guys... Am in the process of buying a laserlevel which i'll probably use mostly for checking floor levels as i do alot of polished marble and porcelain and being from the old school of tiling i dont know much about the types of levels on the market today. So any help here would be much appreciated. Thanks :8:
Hi roadking,
I use lasers alot, however mainly for setting out on floors as the floor laser fires out lines 90 deg apart. Ive a different self levelling laser on a pole for horrizontal and vertical lines on walls.
IF you are looking something specific for levels on floors make sure you speak to Dave at tiletrader direct to make sure the laser will do the job you want.:thumbsup:
laserlevels ???
Tags Tags
usa
roadking,
davy_G,
roadking,
davy_G,
