Perfectly Tiled
Hello guys.
I get alot of work from a local kitchen company and i need some advice.
Some of the jobs im going to that are prepped and not really prepped to the correct standards and as my name is to the tiling id like it to be correct.
First off ive got a 30m2 kitchen to lay in 600 x 400 honed and filled Traveting from CTD.
The current floor is floor boards with 6mm ply and karndean fitted.
My question is what would you now do to prepare the floor, ive said to the guy i can over board it with 6mm Hardibacker and that will be fine. He wants 6mm Ply on there. But im gunna fit HB
Is that ok? i mean to the corretc regs?
Ive got another kitchen to do where he has prepared the floor that is a mix off existing chipboard and plywood where he has fitted the extension. He has now overboarded it woth 9mm WBP.
I no that is not good enough and that is the surface that he wants me to work from.
Again if i overboard it with 6mm HB that will also be fine?
Is there anywhere i can get links or the sort with regulation in there for concrete info that i can give him?
If anyone has any links at all that they can post for me to any type of tiling regs etc ill be more than gladly take and print out
Scotty
Scotty
