Guest viewing is limited
Discuss Laying ceramic tiles on PVC trunking in the UK Tiling Forum area at TilersForums.com.
Tony Boundy
Hi,
Am looking to tile over a vertical length of PVC trunking 60mm wide x 30mm deep which hides the flow and return pipework for a radiator (the trunking gets hot).
The tiles are ceramic with a crackle glaze. Any suggestions on what type of adhesive to use would be appreciated. I would plan to use the same grout as will be used for the rest of the wall tiles (Ardex classic vanilla SF).
Kind regards,
Tony
F
florin66
hi there
there is one way around this problem if you
don't want to replace the pvc boxing... not very orthodox but i have used it few times and never failed.As you know you cannot use tile adhesive on plastic but as is only a small surface you can stick the tiles gripfill. It remain the problem of the grouting.it only works if the grout is white as you have to add (only for that area) a little bit of pva in the water when you mix the grout
Another way of sticking tiles on synthetic surfaces like this,(only small places though) is using good quality clear Silicon.
As a said is only an extreme solution for an extreme problem...(unless u replace the box)
Hope my answer is useful, good luck
AliGage
Subscribed
4,531
1,188
Peterborough, England
Agree with most on here. Re-box with plasterboard. If a jobs worth doing....and all that.
I'm not convinced on the gripfill suggestion though. I would think that the heat from the pipes would have an effect on the bonding of the gripfill over time. But having never stuck tiles on with gripfill i couldn't say for sure.
Tony Boundy
I would recommend removing the PVC and building in a new box section from timber and ply, it would have to be a bigger box to accommodate the timber but that would be my choice
Thanks Mattle40 and everybody else who took the time to reply - much appreciated. The trunking was used to hide the pipes in as small a box as possible. I was hoping a 2 part epoxy resin adhesive would do the trick but I guess from the replies that is not an option. Box the trunking with PB and tile conventionally seems the best option.
Thanks again to all.
Best regards,
Tony
Reply to Laying ceramic tiles on PVC trunking in the UK Tiling Forum area at TilersForums.com
Hi all, I'm new to the forum so please forgive any silly questions, I've taken on rather a big...
8K
Hi all, Tiling my bathroom and wonder if I might get a sanity check!? Got all the tiles out...
J Sid
HI Guys, I am new to the forum and after some guidance. I am currently halfway through tiling...
5K
Hi , thanks in advance for reading and replying ! Im in a bathroom fitter and I've been in the...
21K
Gez2312
Hi guys, Been reading the helpful advice here but now need some of my own! I had a tiler in to...
8K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
