winston6705
Not being to experienced, i would like to ask if laying ply over this compressed chipboard stuff they now use for floors instead of boards is a must? I am laying ceramic floor tiles.
Discuss laying down ply. in the British & UK Tiling Forum area at TilersForums.com.
I think you are absolutely correct here Silver. If the chipboard is solid (no bounce) then the only reason to to overboard is to protect from moisture ingress. BS recommends over boarding to add strength to the floor, not to stop moisture getting at the boards. Certainly with small floors, as long as they are solid, I am happy to tile straight onto if if need be. Some customers just do not want the extra expense.I have found different scenarios with chipboard...Having tried and really struggled to lift old tiles off a chipboard floor.....on one occasion. Never tiling onto chipboard didnt stack up in that case.....wonder what they were stuck with ?
But to be sure I never tile directly onto it. If there is no structural movement underneath (knacked joists) or "spring" Re board over with ply or Hardibacker, use SPFRS and away you go....as is the good advice you the guys have already given.
A tip I was given is that its not the adhesive that fails on the chipboard...its the breakdown of the fibrous surface of the chipboard, brought about by water / moisture ingress . Small 1>2m floors and false back walls behind cooking hobs made from chip board can be tanked to stop the moisture reaching the chip board and breaking it down.
Though I have only used this when raising the floor level by boarding out is a problem.
Reply to laying down ply. in the British & UK Tiling Forum area at TilersForums.com
