Discuss Laying plank wood effect tiles in the DIY Tiling Forum area at TilersForums.com.
I'm planning to diy lay some plank wood effect tiles, size 114x20 and would appreciate advice in terms of what I'll be doing
These are 9mm porcelain rectified tiles, so I'm thinking to go with a 3mm grout line, is this ok?
As these are large format tiles I'll be using a 10x20mm notch trowel, is this ok?
The dimensions of the room are 3.35 width by 6.87 length
I'll be laying the tiles across the length of the floor.
Should I go with a random layout i.e use the offcut from the last row for the next row? or a 1/3 running bond?
Re the 1/3 running bond if I've understood correctly the first row will be laid down as full lengths the second row will be 1/3 and the third row will be 2/3 and the forth will be back to a full length tile, is this correct?
Any advice would be welcomed
Personally I’d go random bond, 2mm grout line, 12mm notched trowel and back skim tiles , and run with the room length.
If i was to go down the random bond route i think the offcut that would be left for the next row would be too small?
Length of room 6.87m
If I've worked this out correctly ;)
114 x 6 planks = 6.84m which will leave me an offcut of 0.3m that's not factoring the 3mm grout joints so it'll be 0.12m offcut I'll be left with
Is there a rule as to what minimum size offcut you should use for a random bond layout?
If i can help it i would want to keep wasting to a mimimim
Tony_C
518
Glasgow
Random bond for me.
You don't have to use the offcut from the first row then, just cut a random length off another tile and continue from there.
The only rule for what size would be to make sure it doesn't leave you with a very small cut at the other end. Also check the box for patterns that are not advised, they may advise no half bond so you would be looking to avoid that also.
Random bond for me.
Random it is then! I'll definitely be avoiding the half bond thanks!
Whatever offcut size i go with should i stick with that size throughout? Or should i adjust the size every few rows?
What grout joint would you recommend 2 or 3mm is there a big difference when laid? They are rectified tiles
I'll be using a U notch 10x20mm trowel
Tony_C
518
Glasgow
What grout joint would you recommend 2 or 3mm is there a big difference? They are rectified tiles
Personally i also would probably go for a 2mm as i just prefer the look and that should be ok for rectified, 3mm is usually advised on floors but i'd dry lay a few to make sure the sizing is ok anyway.
If possible remove your skirting also and leave a gap for expansion and then hide that gap when you refit the skirting. This will also give you some leeway with your cut whenever you come to rip a full length tile length ways.
Cheers Tony
All the skirting has been removed :)
I added another comment to my post, keen to get your thoughts
Alternate if you feel it's going to repeat every row or so, it shouldn't really though
[automerge]1573770637[/automerge]
You will have minimum waste by going random also, also quicker to lay :D :thumbsup:
Cheers!
Just a thought, so I'll use a full tile if needs be for an offcut once the offcut is laid do i lay the remaining tile after the offcut is laid to continue the row along the length of the room or do I Iay a full uncut length instead?
Once done will post a pic, will not rush it and take it nice and slow :)
You should only start and finish with a cut tile. Everything bewteen a full tile 👍
Perfect, so I'm not doubting myself, the first tile I'll lay will be a full tile and I'll continue to lay full lengths until i get to the other end of the wall which will need to be cut short to fit
And then the second row until the end will be off cuts at the start and end, in between will be full length tiles
Or should the first tile i lay be a random offcut too?
You’re over thinking this a little.
the best rule I find is not to have rows with joints any closer than 150mm apart.
If you follow that.
So when you lay your next row, make sure that the joint doesn’t finish any closer than 150mm to the joint in the previous row.
you can make your first tile of the row any size you like, you can always use the off cut on another row further down.
There’s no right way to do it, it’s random!
But for me if the joints on adjoining rows are too close together it can look a little odd.
If you follow that.
I think I am! Thank you for the clarification, much appreciated
Reply to Laying plank wood effect tiles in the DIY Tiling Forum area at TilersForums.com
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
