Guest viewing is limited
Discuss Laying riven slate level in the British & UK Tiling Forum area at TilersForums.com.
simonjay
Laying riven slate, you cannot just rely on following the floor, since the slate are not all the same thickness. So you have to lay the slate to a level. This would be easy with perfectly flat tiles.
But with riven tiles, you could choose to prioritise getting the edges in line and allow peaks in the middle.
Or you could lay a spirit level and say the highest part of any given tile will be on the level, but then the edges might be out.
I suspect the answer is choosing the slate carefully and a compromise.
But any advise about how you level slate, given that a spirit level will often not sit flat across the tiles due to the riven surface ?
Thanks,
Simon.
widler
1,328
England
you cannot get away from lippage on riven slate,like has been said,grade your slate,thick to thin,use the thick 1st down to thin,any badly riven or bent ones,don't use,or use where they are out of eyesite if you must.
as ramic said,any bad ish lipage,dress with a thin chisel,use a wide old joiners chisel,ideal for dressing,just tap along the lip and it will come away
Reply to Laying riven slate level in the British & UK Tiling Forum area at TilersForums.com
Hello, I need to level the joists. The joists are about 2-3 mm out in places. I would like...
    • Agree
[reposted here as it seems much more active] Hi, I’m not looking to tile the floor, but feel...
Qwerty
Q
Hi, I’m not looking to tile the floor, but feel this forum has some really smart and helpful...
I was quoted over £4700 (inclusive of VAT) to rip out and replace my bathroom. This does not...
7K
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
