Discuss laying SLC for beginers in the British & UK Tiling Forum area at TilersForums.com.
stevee
hiya lads , im trying to prrpare myself for going on my own, so in my wisdom id thought id try my hand at SLC
my garage floor is old concrete slabs so im gonna use this to practice on ,rather than a clients house:thumbsup:
so, wheres the cheapest place to buy a decent SLC, and r there any to avoid
ill be trowelling it ,so any tips would be great,ill go for the spiked roller eventually,but for now id like to learn old school ,cheers steve
would this be any good for troweling?
http://www.machinemart.co.uk/shop/product/details/rl-52479-plast-darby
diamondtiling
The tool you have asked about being any good for SLC? Its a darby for walls really, back in the days of putting browning onto brickwork, not really suitable for your needs, Get yourself a decent trowel, they are not very expensive. As for which compound to use, well that will come with experience, if you have never used them before and your just learning I really dont think you would know the difference between a good and bad one at this time, I use latex SLC buts more expensive than most, go to B&Q and look for the bags that have been punctured, you can get for a few quid and then have a practice, you will have to bond the garage floor or else if wont stick.....goodluck
:thumbsup::thumbsup:
diamondtiling
spiked rollers are really only used for improving the finish of the compound by removing air and breaking up surface tension. Ideally you want to be using a pin or skid leveller to get the floor perfectly flat, then spike roll it.
I thought everyone used these nowadays?
not everyone,
:20:
bal
There are some great SLC about but if your floor to be screeded has deep troughs and dips its no good just tipping your SLC over the lot and running a spiked roller over it your just going to contor the bad floor , the teeth on a spiked roller are only 10mm -12mm if your sub floor has a 20mm depression and you run your roller over it youll push the screed from one point to another , get a long straight edge find your low points mark the area and screed & feather to your high points.
Rob Z
Steve, I've never tried to use a darby or the spiked roller that some one mentioned above, but instead we sometime uses a stiff rake to break up the edges between two sections of the pour that is going in. THe key thing is to keep a wet edge so the next bucketful of SLC can flow into the previous one. I'd like to see one of the rollers that you guys have avaialble. :thumbsup:
There was another thread recently about SLC's....it had some good tips for you. Dave, could you find that thread for Steve? :thumbsup:
Reply to laying SLC for beginers in the British & UK Tiling Forum area at TilersForums.com
24K
Deleted member 57709
Hi all. First time poster here so thanks in advance for any help you can give and apologies if...
14K
Hi, i'm Tim and I am new to the forum. So a quick intro from me, im an electrician but a quite...
6K
peterparker
Hi guys I'm going to try to tile my bathroom. On the pictures you will see two old window...
White Room
Hi all, This is my first post and as you will see I am not a tiler and have little knowledge...
The D
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
