Laying travertine outside on the roof of an extension
GatesheadCol
Hi Guys,
Ive been asked to lay travertine tiles on an outside area. The roof of an extension to be exact. The roof is structurally very strong, enough to take the weight. It has been laid with felt however this is being ripped up and covered with 18mm WBP ply.
Firstly is travertine suitable for outside areas in our climate? North east englands to be exact. Im actually thinking of not doing it because ive only doen 2 floors in travertine and although very successfully installed the thought of these tiles cracking with moisture and freezing terrifies me.
Any advice would be greatly appreciated, or if another tiler in the north east fancies taking it on, as I now work full time too then give me a shout.
i've always thought that trav was for interior use only Col, altho' I could be wrong. Can you ring the manufacturer to see if they approve? Doubtless other tilers will soon have their input too:thumbsup:
The guy has imported them direct as his business is fireplace surrounds unfortunately. I have read differing opinions on travertine , it can be used outside but the thinking seemss to suggest that our climate is not really suitable for it.
TBH Im terrified of this one lol
One website suggested they should not be laid outside with mortar, just laid over a suitably flat and even surface - Dont get that one unless a bed of sand or soemthing was used.
i would,nt advise fix trav outside on to a timber floor ,the change in weather temps will warp the timber
over time and hurt the integrity of the tile
I couldnt believe what I was reading, travertine is absolutely not suitable for this type of installation. This is a fragile material riddled with air pockets, even with applying a sealer this will eventually wear away and leave the material to absorb water which will eventually break it down.
Save yourself the grief and walk away...
Pebbs
phew:hurray: at first I thought that maybe an exterior trav must have come onto the market:lol:
I've got 22mm thick Travertine on my Patio.
You all had me worried for a moment there I was beginning to think this was a man made product and even though it had been outside for millions of years it wasn't suitable!:lol:
I find some replys very strange from tilers...
Travertine is fine outside.. totally fine.... the thing that isn't fine is the substrate they intend to fit..Personally i would be looking at un-coupling it as well ...I would use the 12mm Aqua type panels glued and screwed and then Ditra..
But trust me, travertine is fine outside..
I must admit that I always thought that because it was so porous it would shatter with the freeze/thaw fluctuations. As TJ says, it has been around for billions of years, but this is underground John, and not really subject to frost (imo)
The thing is Doug the 12mm travertine you have fixed in interior bathrooms is not the product I would find suitable for outside work IMHO.
And as Dave has pointed out its the substrate that is the issue for this balcony and its preparation.
travwetine totally fine outside...trav pavers etc :thumbsup: and i would most definately use a decoupling membrane too!!
Cheers guys, The customer is laying a gmat over the substrate which will be 18mm WBP ply laid over the exisiting substrate.. Yes it is a roof, but will also be a balcony having french doors from the living room. I might still leave it though as i work full time and its a lot to do on a weekend.
Does anyone fancy it?
I always miss the good 'uns, :drool5: only home for a couple of days and the family want to see something of me before I go again :mad2: :lol:
Col, get it done ,mate, get the prep right, and your away, just explain to the client that it might take a bit longer than average :thumbsup:
GatesheadCol,
Alan.P,
GatesheadCol,
Alan.P,
