justinisaac
Hi all, hope this is in the right forum!
I recently re built our bathroom from top to bottom, including replacing 8 floor joists and removing and replacing the ceiling. I took quite a while to do it so that I could make sure that everything was as I wanted it so I was mortified to discover after a few weeks that the shower is leaking. After further investigation it appears that the join between tray and tiles is the weak spot. It seems that the silicone, while adhering well to the tiles has not formed a strong bond with the tray and water is getting drawn under the silicone. The underside of the silicone is already discoloured with mould and if you push it with your finger the water held underneath oozes out.
This is the first time that I have had a problem of this kind. Has anyone out there had a similar problem?
I don't know what to do to be honest so any advice would be greatly appreciated.
Cheers
Justin
Cheers
Justin
