Discuss Leaking wet room in the UK Tiling Forum area at TilersForums.com.
Will
Hello,
I was hoping for some advice, I recently bought a house that had an main family bathroom with "upgraded" shower wet room. It is located on the first floor, over the garage.
From the outset it has been a bit of a nightmare, with water leaking though the floor into the garage below. I have been able to identify the leak to the grout both around the top of the brown tiles (where they meet the beige shown in picture "side") and also where the vertical brown tiles meet the shower base. The grout has deteriorated badly, considering installed in 2008. I have had the shower resealed with silicon (several times) which stops the leak until the silicon breaks down. I was after some advice to provide a more permanent remedy, and was wondering whether replacing the grout with epoxy grout then sealing with silicon would do it or whether the tiles need to come out and be relaid. I don't know the method of construction and am trying to find out from the prior owner. Any thoughts more than welcome!
Regards
Will
Deleted member 9966
Hi Will
I assume you purchased your house after the new shower area had been installed? If so, did the previous owners leave you with any documentation regarding the company/tiler who re-fitted the bathroom? My first port of call would be the original installers. If the shower area is failing in only 2 years, knowing how it was installed to start with will help you to identify what you need to do to rectify the situation.
As you have said that re-siliconing stops the leak only temporarily (until the Silicon breaks down) continuing to re-Silicon will not be a long term problem solver. Have you re-siliconed yourself or did you get a tiler in to do it for you?
When you say the Silicon breaks down, what do you mean by this? Is it detaching from the tiles? If the shower area is rigid, and the Silicon is applied correctly according to manufacturers instructions, I'm struggling to see how Silicon will fail so quickly.
:welcome: to the forum by the way. There are lots of pro tilers on here who encounter these issues in their working lives, so you've come to the right place. We have a number of members in your area who would be happy to come out and have a look at the issue with you.
GRR :thumbsup:
Will
Hi, yes the wet room was installed and I am trying to extract the name and number of the plumber/tiler who installed from the previous owner and agree knowing how it was constructed will help. I can tell from below, that looking up from garage a new suspended timber floor was put in but cant deduce anything else.
I had a plumber reseal the shower, which worked but then it leaked from a small hole in the grout on the wall (where the brown meets the beige) so to make sure this was the problem I covered with silicon and it stopped. Subsequently the silicon round the base has lifted in the corner and the leak reappeared. I stripped it out last night and it was wet behind the silicon and I noticed the grout was breaking down around the base. That is it is crumbling and wet. Parts of it have come away with the silicon.
Will
Deleted member 9966
I'm concerned that the shower area is bouncing around/not rigid enough for people to be walking on it.
Is it only around the bottom area that you can see a problem? Is the grout deteriorating any further up?
Also, does the water drain away easily or does it sit around and not flow to the drain after the shower has been used?
When you get hold of the original installers, ask them what the floor is made up of - ply, aquapanel/cement board and ask them what thickness.
Deleted member 9966
Will
Yes you are right, I tried to upload another photo but think it is too big, i will try and ZIP it. It does hit that wall and it is that wall specifically which is the problem, or has been. I will have a look at your members site, I dont want to try and quick fix myself, whilst I am quite handy, and my Dad is a retired builder of 46 years who I used to work with, it out of my comfort zone, well that it is to say I want a professional long lasting remedy. My Dad's view was not complimentary, first he disliked strongly a wetroom upstairs and predicted from the outset it would fail at some point. I need to get it reolved one way or another and if that means refitting then so be it.
Rich
Hello Will and welcome to the forum.
There should be no reason why you cant have a wetroom on the first floor as long as it is installed properly. This wetroom has not.
It sound to me that that the tiler has grouted the interior angles (between the floor and the walls) and siliconed over the top. This is wrong because the grout will crack and split over a short period of time and take the Silicon with it. If this is the case the grout in ALL the interior angles needs to be removed and replaced with a Silicon joint. If this is done correctly there should be no way that the Silicon fails that quickly unless there is a huge amount of movement in the floor. You havnt mentioned the rest of the floor, Is there and cracks in the grout or are any of the tiles cracked in the rest of the room?
My main worry at this stage is that the water that has already made its way through the tiling would have done some serious damage to the substrate and it is going to be a major job to put right Im afraid.
Will
Hi there, that certainly seems to ring true, that is there is grout with silicon over the top. The water ingress is coming from that side and making its way though the floor into the garage below. In terms of removing the grout and then using a silicon seal is this as simple as it sounds?
Is it worth trying this or as you say the substrate may be already damaged and therefore will not provide a lasting solution? Would there be other possible cures such as installing a tray? Sorry to bombard you with Q's!
Rich
Thanks, I am currently trying to get in touch/get the details of the original installer to understand how it was contructed. If I cant do you suggest ripping out or trying to re-grout and then seal?
Sorry Will, I missed this post. Do everything you can to get hold of them. the problem is what the water has done to the substrate. Regrouting will not help the damage done to the wall behind the tiles. You will need a pro to come and take a look I think. :thumbsdown:
Reply to Leaking wet room in the UK Tiling Forum area at TilersForums.com
  • Sticky
Shower Tile Repair - Tile Waterproofing in Brownstown MI. Schluter wet room conversion 24h...
  • Sticky
Advice needed, noticed some grout that was cracked and tiles becoming loose in our en suite wet...
We've had a wet room installed upstairs using the Impey wet room system (see attached). The...
Leaking wet room
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
